Parametric nested family
Hey everyone, I'm trying to make a sweep HE220A beam (European I profile) that works and cuts under a non 90 degree angle.
It has to be a Shared Nested Parametric family so I cannot just draw it and use voids. The rotation of the sweep is difficult because I also need a reporting Length parameter. Because it's Shared Nested, this makes it buggy. I'd like to circumvent that as well.
Juanfranciscoangel
hello did you solve the problem if so you can comment
Juan Francisco Angel
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Luego haga clic en el botón ACEPTAR SOLUCIÓN.
I have not been able to fix this yet. I will look into it later as this has been put on pause
