Group object is not copying one level to another level
Message 1 of 17
Hi all members,
How r u all????
I am back once again.
I am facing a problem when i want to copy a "Group Object" from one level to another level. I have sending some images for yours better understanding. Please can anyone help me on this issue???????
I shall be greatful who will solve this problem.
Thanks & Regards,
Subhradeep Sen
Kolkata
India
Replies (16)
Message 2 of 17
sureshchotrani
Try using Copy from clip board in plan view by going in Modify/Clipboard/Copy & then going back to where you need the same & selecting Paste/Aling to current view.
Also while you are copying in elevation are you selecting disjoin on left top corner under options after selecting.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 3 of 17
Hi Suresh,
Thanks for your prompt reply.
But I have already tried all the options to copy this group item. But no way to resolve this problem. Again and again same massage is giving when i am trying to copy this group item.
Have you any other idea about this matter???????
Subhradeep Sen
kolkata
India
Message 4 of 17
okapawal
What kind of objects, categories, are included in this group?
This kind of issue could happen to reinforcement or truss elements.
What Revit version do you use?
Waldemar Okapa
Software Quality Assurance & Testing Engineer
Message 5 of 17
Thanks for your reply.
It is a combination of Column, Beam, Slab & Stair objects.
All are Concrete Categories.
No Reinforcement objects are present here.
I am using Revit 2014 version.
Thanks & Regards,
Subhradeep Sen
Kolkata
India
Message 6 of 17
sureshchotrani
Kindly share the file on Dropbox, I would like to check at my place.
Message 7 of 17
Hi Suresh,
How can i share my Revit file in drop box? Where is drop box option?
i can only see the attachment option.
Pls help me.
Thanks & Regards,
Subhradeep Sen
Kolkata
India
Message 8 of 17
sureshchotrani
Go through my article on sharing BIM model here
At above link you will have to first of all need to sign in with A360, then you can share a link with me.
Message 9 of 17
i have uploaded. can u see the file?
Message 10 of 17
sureshchotrani
Kindly share a link to my email address, [email protected]
Message 11 of 17
have you got it now my file?????
Message 12 of 17
have u got my revit file?????
Message 13 of 17
sureshchotrani
It copied nicely without any error,
Message 14 of 17
are u copying it after making group??????
Message 15 of 17
sureshchotrani
Yes, will mail you the link of the file.
Message 16 of 17
Hi Suresh,
Hope you are fine.
your answer is not a complete solution as well against my query actually. What you have shown it is clear to me and also i know that. But when you will copy a "Group Object" exactly to the back to back level that problem and error is till now persists. But in alternate level it does not a problem at all.
Try with the figure which i have posted at the very beginning. Copy that group object back to back level. then you will find out the exact problem. Hope my uploaded revit file is with you. Try it on that file.
If you find out the solution about this problem then please inform me.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Message 17 of 17
sureshchotrani
I deleted your inplace columns
After that it copied nicely
I recommend you to not use the inplace objects as they are very risky many a times I have seen them getting placed somewere in the file were they were not actually located.
