Grid name along axis
DanielsenAS
DanielsenAS
Community Visitor
Community Visitor
Is it possible to add grid name along axis. As i can see it is only possible to add grid name to end 1 and 2. I would like to add more options and have Grid name along the axis as well.
Possible?
JL.FCG
I would also be curious to know if this is possible, however I believe it might not be.
You can change gridlines as per the below link, but doesn't seem to mention about being able to add letters/numbers to the grid line sequence.
You would somehow need to make a new Line Pattern Property, as it stands its only 'Dashes, Dots and Spaces'
https://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-6E5C3207-CA80-452A-9DD8-CA94CD592E51
handjonathan
Hi @DanielsenAS
Thanks a lot for posting your question to the forums!   Has the solution suggested by @JL.FCG helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
SteveKStafford
Not as part of the grid family definition itself. You could create a repeating detail family that uses a detail component that provides a number that can be repeated along it's length. That would be view specific. A 3D approach, so it would be visible in any view or exported to Navisworks for example, could use a line-based family and array of 3D text to show the number along it's length.
Steve Stafford
