- Mute
- Permalink
- Report
I am working on a high rise project and I am using Revit 2018.3 for BIM. I am trying to create a set of sheets on which to show the column schedule but the schedule keeps disappearing from the viewport (i.e. view is completely empty). The schedule is however visible when I access it through the View>Schedules>Graphical Column Schedule option and the columns are definitely modeled.
I have checked whether the issue might be caused by visibility settings but it appears not to be the case as all necessary worksets are loaded and turned on, as well as the categories and subcategories. The elements are also not hidden in view.
In the past, the problem was solved simply by turning on and then off the "Reveal Hidden Elements" mode which may indicate that the issue is caused by a bug. However this time, that approach no longer seems to work.
Therefore, I was wondering if anyone had the same issue and if so, how were you able to solve it?
Thank you!
