Going Through Daniel John Stine Design Integration Using Autodesk Revit -- Stuck on Chapter 8 -- Structural.
Slocumb
Observer Observer
Message 1 of 8
Slocumb
Observer
Observer
I am having problems on Chapter 8--Where the views that we are asked to import on Page 9-ish cause problems later in that they are greying out the view edit. When I go through and manually edit the views (View, manage templates, Structural Framing Plan) I see that the views are all scrweed up and doors and weird stuff is showing up--despite me and a friend restarting several times.
The Structural is showing up under the 1st floor but still showing up on the 2nd floor plan -- manually moving stuff around sort of works, but then disappears from each plan view (From all 3, the first floor, second floor, and roof). The tags still show up though. I will attach my file below so you can poke and prod all you want. ISBN of the book is 9781630574512
I'm not an expert--just a student, so I'm not as nearly as good at this program as the professionals out there. Please enlighten me!
I will also go ahead and attach the chapter 10 starter file so that you have a reference of how chapter 8 is supposed to look like afterwards. (chapter 9 does not add anything to the building).
Replies (7)
Message 2 of 8
hmunsell
isn't there a Support Number with the manual? I'd start by calling the makers of the instruction's manual 😊
Other than that, in a Revit Structural view, you will only see "Structural" elements and elements that make openings (Windows, Doors...).
There are also difference's in the Structural Framing View templates in the 2 models. don't know if that is intentional or something your supposed to fix over the course of the class.
Again... id find the support number for the course and ask them.
Howard Munsell
Message 3 of 8
Slocumb
Observer
Observer
I also noticed a difference within the files like you said. I couldn't figure out why that was because it is not figured out through the class -- the book lists out to explicitly ad those view templates so I don't know why they're gone in the next starter file.
I'll talk to the book support team and see what they come up with -- I did go through an online support (email) process but that did not yield anything meaningful. My instructor is also stumped (He's been doing mostly residential design for 30+ years, so even this is a fairly new thing for him).
Message 4 of 8
hmunsell
looks like some inconsistencies in the dataset? I can give you several options of how I would correct the view issues, but hesitate because I don't want to mess anything up for you later in the class :-).
Howard Munsell
Message 5 of 8
Slocumb
Observer
Observer
Appreciated. The instructor is as stumped as I am!
Message 6 of 8
hmunsell
in your Chap 8 model.... in the Level 2 Structural Framing view....
  • set the Underlay settings to Level 1 > Level 2 > Look Down
  • edit your Structural Framing View template
    • open the Model Display, Edit... button
    • change the Model Display Style setting to Wireframe.
  • another issue is the Level 2 Structural framing view in Chap 8 model has its "Associated Level" set to Level 1. it should be Level 2... so the view was not set up properly.
    • it looks like it was copied from the "Level 1 Structural framing" view vs made using the View Ribbon > Create panel> Plan Views tool.
just some things to check... 😉
Howard Munsell
Message 7 of 8
Slocumb
Observer
Observer
I'll check through that tonight thanks!
I remember the book specifically asks for you to copy the view and rename it -- so having the wrong associated levels seems to have come down from the book--but I'm no pro--the book tends to skip a few steps sometimes and I don't know quite enough to figure out the few steps inbetween.
Message 8 of 8
hmunsell
I've had users do things incorrectly on occasion so they can see what issues it causes.... Maybe....  😆
That view should have been made by using the Plan View tool, selecting a Structural Plan option
Then pick the Second Floor option
if second floor doesn't show up in the list, uncheck the check box on the bottom of the window
Howard Munsell
