Glulam material physical asset parameters explanation
ouspensky
ouspensky
I am working glulam bamboo beams and I need to modify some properites of the physical asset of a generic glulam material.  Where is the documentation for these properties (see image)
Glulam PropertiesGlulam Properties
1. Mechanical > Behavior (i.e. what is meant by isotropic, transverse isotropic, orthotropic)??
2. Strength>Construction (i.e. what is meant by Natural, KertoK, KertoS,ect.)
3. strength grade?
4. and why are yield and tensile strength set to 0?
thanks
teodorb
Hi @ouspensky,
Here are some explanations:
Isotropic material: https://www.quora.com/What-are-homogeneous-isotropic-anistropic-and-orthotropic-materials
Transverse isotropic vs Orthotropic: https://www.quora.com/What-is-the-difference-between-orthotropic-and-transversely-isotropic-material
Most likely this is the construction method to obtain the element.
3. strength grade?
There are different grades for this. here is an example:
http://www.nzwood.co.nz/faqs/what-strength-grades-should-glulam-be-designed-to/
Coudl you tell me where did you get this from? The actual material assset?
Bogdan Teodorescu
Product Owner
ouspensky
3. Are the different construction methods (natural, KertoK, KertoS, ect.) used in the structural calculation?  if so how are they used? why are we only given these options?  can we make our own construction methods ? is it useful or necessary to make our own construction methods? how can we make our own construction methods?
4. Yes the defualt material asset parmeter for glulam wood is defined as  "0"
ouspensky
An additional question:
I tried to make a custom material as transverse isotropic and it caused an analysis error: Incorrect Poissons Ratio.  What are the guidelines for entering poissons ratio?
anisotropic materialanisotropic material
