Framing Connection Symbol Overlap with Arch Link model
tbhardwaj-MI
tbhardwaj-MI
Hi
I noticed when we have Arch model link in Structural model , there Steel framing connection symbols are overlap by Arch Link model in background. which is not good for Structural framing plans, please any one have solution
ovidiu_paunescu
Hi @tbhardwaj-MI
You can override the view graphics and uncheck the connection symbols category, to not show those symbols.
Also, if you change the detail level to medium or fine, those symbols are not displayed as well (but the geometry of the structural framing is displayed in more detail, which may not be what you want)
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
VG > Revit Links tab > Select the link and Tick Underlay box.
tbhardwaj-MI
No i want to see framing connection in plans my question is Arch background line is overlap on connection symbol
ovidiu_paunescu
Then you need to override the view and turn off the categories that those elements belong to.
If those are architectural walls, you can also try changing the discipline of the view to Structural (instead of Architectural)
