Setting up the survey base point in revit
descartinberna10
descartinberna10
Hello!
I hope someone could help, we are currently setting up a project and the first thing we need to do is set up the survey point for it to be shared to other discipline this revit file contains only the topo file from AutoCAD.
The thing is the surveyed point determine is the corner of an existing building, so is it correct that on our initial setup the coordinates of the survey point and the project base point is the same?
ennujozlagam
check this one if helps. thanks
https://www.youtube.com/watch?v=7l-IITOGL6Y
@descartinberna10 wrote:
Hello!
Yes if you prefer the Project Base Point also at the same corner of the existing building.
