how to create separate architecture detailed view and structure detailed view for same cut plane.
REDO10
REDO10
Hi all
I would like to create a separate detailed view for architecture presentation (to indicate only dimensions in the print sheets) and structural presentation (to indicate only detailed rebars in the print sheets) for the same vertical cut plan...so how can I do that please?
EdwinG
duplicate the section and set a different View Template where all rebar is disabled
REDO10
Hi @EdwinG
Sure, I've done it before....but my problem REVIT don't let me select the cut's architectural symbol in plane view called Coupe 1-1 architecture to modify it's extension and setting, REVIT highlight only the section Coupe 1-1 structure to be selected!! (see pictures below)
and when I enter in Coupe 1-1_Architecture from project management tab I can't set correct visibility setting to show my drawn model lines!?  see picture below
how to solve those problems?
Thanks.
EdwinG
If element are on the same place you can toggle between those elements by pressing TAB
Hoover above your structural section and press tab then select the section below.
REDO10
Hi @EdwinG
I've duplicate my section called Coupe1-1_Structure to Coupe1-1_Architecture from project management tab, but this section does not really exist in 2d view plane !!?? ....I had to make another one to be able to select it in 2d view plan.
another question: How can I permanently hide the line shown in the picture bellow and keeping dimensions shown?
Thanks.
EdwinG
Don't dimension on the line you want to hide.
It is better to dimension your concrete elements, you can select a cornerpoint of the concrete by pressing tab (multiple) until a blue dot appears (can be very small).
REDO10
@EdwinG
As you see I've a dome and in the upper of the dome I've a voide and I can't select any element to have correct dimension that should be 3.60m
Thanks.
