floor tag
floor tag
andy.van.slambrouck
floor tag
andy.van.slambrouck
Hi all,
I would like to make a new floor tag wich I can use on my foundation plans when I use a single plate for foundation.
I duplicated a floor tag and changed it so it shows the top elevation and the tickness from the plate, these values are shown in a circle.
 But now I would like to add 4 lines starting from the center of the circle(tag) to the corners of the plate to somehow represent the area of the plate kinda like a span direction but with diagonal lines in this case.
In the attachment you can see an example of the tag I would like to have too.
N.Oomen
Hello @andy.van.slambrouck,
What you are trying to achieve would be done with a span direction family. Those are available as standard families with metric/imperial revit library.
Go to Annotate Tab -> Symbol Panel -> Span Direction button.
If needed load the family from your metric/imperial library location.
This symbol can be placed and even rotated the way you want to.
Hope this helps you out.
To make it easy I have attached the symbol.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
andy.van.slambrouck
Hello N. Oomen,
Thx for your advice, I tried it before already with this span direction family and tried to edit it. But didn't knew you could rotated it too 🙂
If I can change the family without the arrows I could use it for what I wan't.
Think it will work now.
jose.almeida
Can you please tell us how did you solve this?
