I have created a schedule to identify the rebar type, lengths and quantities in Revit 2016.
The difficulty I am facing is when the identical rebar type is used it displays in different rows. The solution may seem obvious by unticking the Itemize every instance box under the Sorting and Grouping. However, this only results in a single line and quantity in the schedule. Any other instance of the same type is excluded from the schedule.
I am trying to achieve the outcome as illustrated in the following link by Autodesk; https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN....
I have attached the practice file for reference.
Any help is greatly appreciated.
