Filter and select or delete rebar by number
is there a way to "Filter and select or delete rebar by number"??? What is the fastest way to select and edit rebar from schedule??? I have 200+ rebar numbers and trying to find some in model is a little bit time consuming.
Regards!
ovidiu_paunescu
Just open the schedule and a regular view side by side.
Filter the bars according to the Rebar Number or other criteria in the schedule.
1. Select the rows (click and drag)
2. Switch to the view
x. Delete the selection
Alternatively
Add a filter to the view that hides all the other bars (the ones you want to keep) but the ones you want to delete
Select the bars and delete
That's it!
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Thank you! This is what I was looking for!
