Hello everyone,
I have a pile family that has a generic symbol family inside it - this symbol contains filled regions.
In my plan view I cannot make the filled region appear unless I set the Model Display to consistent Color or Shaded.
Is there an option where I can make my filled region symbol even if its set to wireframe?
I cannot adjust my view range anymore because the piles that I need have already appeared in this plan view.
I just need their symbol (with filled regions) to appear here.
Thank you to those who will anser.
Solved by gevanKGYB4. Go to Solution.
If you want your foundation to appear hatched, I think it is much easier to do it with VG model rather than using filled region in the family. Very easy to change the hatch pattern as well as colors. But if you want the hatched to be only on the pile caps, not all foundation, you may need to use filter instead of VG model (basically same idea).
thank for this suggestion.
although I need my piles symbols (with fill) to change as I change my pile sizes.
the work around that I did is to omit the fill on my symbols, as I cannot make the filled regions to appear on the model, even though I have correctly included those on my family.
