Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Fabric Reinforcement - fabric cut by internal opening listed as same number as uncut fabric
0 REPLIES 0
Message 1 of 1
petrlanik
96 Views, 0 Replies
If the fabric reinforcement is cut by internal opening in the slab or crosses two boundary lines on slab boundary indent it displays correctly, but for all of these the same fabric number is assigned. Also the symbol line is only presented in one part of divided fabric and is not correct for fabrics cut by openning. Only workaround for this is to have two or more slabs with no indent or opening, but then arrises. Also we are still missing the cutting schemes of fabrics
I can use Graitec PP4R for schemes of fabrics, but then there is a problem between fabric numbers and cutting numbers, as in Revit it is still considered as one fabric, while in PP4R as two separate ones.
0 REPLIES 0
