exporting dxf files for later use in V carve
hvcprecast
hvcprecast
Good morning, has anyone ever exported dxf files and used them in cnc softwares , i can export them but they come out all messed up with double lines and then i have to clean them up , but i want to work with huge amount of files , any idea will help , maybe mine setup is not correct
John
jay_colcombe
There may be more specific Tools and Addin that could help or make this easier
Perform a CAM export | Autodesk
Jay Colcombe
Autodesk Certified Instructor
hvcprecast
do you have any leads
John
jay_colcombe
You have the Tool in the precast tab but this lead may help
https://agacad.com/blog/running-cnc-machines-from-revit
Jay Colcombe
hvcprecast
Ok I found a work around to export DXF Files and STEP files , But my isuue now is in a DXF file i do not have a problem with exporting Tag or mak number with my DXF file , as it works perfect and i can get the cnc to write that on my sheets i need to CNC, but how do i get a tag number placed  a 3D or a STEP file .
John
