Export to PDF issues with empty view comments showing weird graphic
arautio
arautio
Was all exited that for once I might be able to print 10 sheets without having to sit there and put in the correct pdf name for each and every darn sheet.  Used the exprort to PDF with sheet number as the namaing parameter,  thought it all worked out fine until we scrutinized the prints (see images).  Printing to PDF no problems,  just the annoyance of having to type each sheet name as the prints complete.
The result form print to PDF
The result from Export to PDF
PLEASE ,  for once I would just like to send my prints and not have to sit there and rename them ALL!!@!!!!!!!!
And if you try to sell me some third party software, I will do my best to figure out how to smack you in the face.
Yes you can print multiple sheets or views and PDF will name them automatically.  Look into your PDF printer output preference.
arautio
No Sir  seems NOT to be the Case, and there are no file options on the Layout or Paper Tab, and I got no more tabs, and Revit has no setting for it,   so tell me where please?!          And we will not use bluebeam, half the office opens them and they are blank.
Set it to a folder, not Prompt to Adobe PDF filename.
