Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
export a rebar construction to advanced steel
1 REPLY 1
katsanosengineer
125 Views, 1 Reply
I have made my concrete basement in revit and the upper steel construction in advanced steel and now I want to combine the two projects into one.
I exported my revit project through advance steel extension but when I insert it in advanced steel my rectangular columns turn round and all the rebars disappear.
Can you please help me?
1 REPLY 1
Is the mapping into Advanced Steel Correct?  I can only assume that there is something in the process where the elements are being replaced with alternatives and as regards rebar I am not 100% on this one but would have thought you could create a Family/Style to replicate the Mapping with a Shape/diameter/Grade/etc.
Jay Colcombe
Autodesk Certified Instructor
Forma Design Contest
