- Mute
- Permalink
- Report
Firstly I'm not a structural Engineer or modeller, I'm an Architectrual Model manager... I'm trying to model an existing building that is a realtively simple portal frame, but not a modern portal frame.
I've watched a number of online tutorials, but they all just seem to deal with modern traditional diagonal sloping haunches.
Im not sure if the shape at the top of the columns with all of the web plates is classed as part of the column or maybe part of the beam...?
Can anyone suggest the best way to approach this...?
This is just to provide context and doesn't need to be capable of being structurally analyzed...
I could just model this as a simple family using dumb 3D geometry, but why pass up the opportunity to learn something new...
The left images is the central column headand the left smaller image is the outer column
The sketch below is just linework and shows the approximate profile of the main portal
Thanks in advance
