I have a sheet list set up which uses a combined parameter "Sheet Details" to concat the sheet number and sheet name into the format I require. See Below.
But is it possible to exclude the "Sheet Details" row from the list when you are dragging it onto the sheet with the same sheet number?
i.e. If I put the list onto sheet number 00110, the "Sheet Details" row for 00110 will not appear in the list. Similarly, if I put the list onto sheet 00111, then that row would be omitted.
TIA
