Exclude current sheet from sheet list
ezcad.co.uk
ezcad.co.uk
I have a sheet list set up which uses a combined parameter "Sheet Details" to concat the sheet number and sheet name into the format I require. See Below.
But is it possible to exclude the "Sheet Details" row from the list when you are dragging it onto the sheet with the same sheet number?
i.e. If I put the list onto sheet number 00110, the "Sheet Details" row for 00110 will not appear in the list. Similarly, if I put the list onto sheet 00111, then that row would be omitted.
TIA
hmunsell
if i understand your question .... just hide the field you dont want to see.
Howard Munsell
ezcad.co.uk
Hi Howard, thanks for your reply, however, I think you misunderstand my question.
The idea is that if my sheet list is dragged onto sheet number 00110 for instance, then just the row in the list which shows the details of sheet 00110 will be omitted from the list.
hmunsell
You want the schedule to update based on the sheet its placed on? I don't know of any way to make a schedule "Sheet Aware" in Revit. only thing i can think of is making separate schedules.  maybe someone else can provide another idea?
Howard Munsell
Vik.Mohite
Try this one,
Go to the sheet which you dont want to appear in your drawing list and uncheck,(Appears in sheet list)
This will take the particular drawing out from the drawing list.
lim.wendy
Hi Steve,
Good day to you
Thank you for submitting your question in our discussion forums. Just wanted to check with you for an
update on this issue. Have you had a chance to look over the suggestions provided by our experts?
Please let me know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
steve.ruddY23AK
No, I did not get a solution to my question.
I do not believe REVIT has the functionality to achieve what I want, but the workaround is to create individual sheet lists with the necessary filter applied.
