Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Element joint visible problem
7 REPLIES 7
Message 1 of 8
590 Views, 7 Replies
I have created a nested family with a rectangular family nested with haunch. In family there is no joint is visible between beam and the haunch, but when it is loaded to the project, the joint is visible and annoying.... Can you please help in this issue.
Thanks and Advance
STM
7 REPLIES 7
Message 2 of 8
UPLOAD FILE
Message 3 of 8
I here attached the family file. Please help in this regards.
STM
Message 4 of 8
ArmanMargaryan
You should probably use a complete element.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Message 5 of 8
in reply to: ArmanMargaryan
Can't understand....
Message 6 of 8
ArmanMargaryan
Use one complete Model In-Place. I'm attaching my change to your file. I hope it works out
Arman Margaryan
Linkedin | Facebook
Message 7 of 8
Thanks for your reply. Actually. We have created the family and used in the entire project. Haunches need to be in visibility control and also controlled by parameters. Model in place element are not allowed by the team.
Thanks.
STM
Message 8 of 8
ArmanMargaryan
Was the problem solved?
Arman Margaryan
Linkedin | Facebook
