Exporting Reinforcement Schedules to XML file.
markkibui101
Message 1 of 8
markkibui101
Hi
Anyone who knows how to export a reinforcement schedules to an XML file? I need to submit the schedules using a program called Q-Armering and it only reads XML files. I know dynamo can do this but I am not quite familiar with it. Is there a plug in or any other way to do it?
Replies (7)
Message 2 of 8
Jamhmer_Oc
You can't directly, but using dynamo you can.
Before running you have to download the Bimorph Nodes, Lunchbox for Dynamo and Lunchbox Quad Grid by Face packages.
Now you have to choose the correct table and run.
Here is the script.
Jamhmer Oc
Message 3 of 8
HELPED?
Message 4 of 8
markkibui101
I am getting errors.
Message 5 of 8
markkibui101
doesnt seem to work yet. I have attached the dyn file
Message 6 of 8
markkibui101
I am dealing with Reinforcement schedules, so I don't know what to change in the script.
Message 7 of 8
hvcprecast
Thank You
John
Message 8 of 8
anze.kumar
You could try exporting your reinforcement Schedules to (.txt -> import to excel) excel and then from excel -> XML files.
You would need to be careful however, the way you structure your schedule in revit, so that it corresponds to the way you want it in excel (rows and columns)
