Hello folks,
In Revit 2017, in the worksharing, central model system; as there are many users, and as the model gets larger with 5+ members, at some point nobody knows who changed what.
I want to find out if there is a way to see a history of a changed elements. Is there a method to see a list of users and their changing records?
Any help much appreciated.
best regards
Actually I have found a way that shows the latest update in the central model by user.
In a 3d view when you select Worksharing: Display Model Updates from the buttom ribbon, it opens up a view that you could see the latest updates of the elements when you hover on them. There is no history but at least you can see the latest person who was working on the element.
