Error in Saving as Central Model
Facing issues in saving as a Central model error comes as a
Central-project.rvt is read only or opened by someone else. However its not opened by anyone and how could be it ready only ?
I opened central model and trying to save as central on another server location. I can see check box is visible to save as central and when I check the box to save as central and try to save the error msg comes up. I have feeling its due to change to central model file server location. is there any solution to save as central on new server location ?
ennujozlagam
hello, it could be server issues. you can try this relinguish all mine all users , open  again discard all worksets and create a new fresh central file and forget to audit your file and see if helps. thanks
HOW  do you relinquish for all users
ennujozlagam
hello, go to all users involve in the projects and relinguish all mine. please see attached
Thanks for reply. all users relinqueshed. It did worked able to save back as central and can create now new local file but probelm is not entirely solved. when I try to sync now new local created from central model again the same error msg appears.
I checked the properties in windows dialogue right click and go to properties and I can see in Details the owner where my name appears( I created one new file for test) it doesnt have the problem to sync file and where other user name appears as owner have problem syncing in the file and error comes.
ennujozlagam
hello, now we know its not your network issue? the only think i can think of is try to clean as much as possible  of all your warnings, have you try to audit and clean as much as possible in your new central file? thanks
what is the error messages?
or try to install latest updates form autodesk
and all users in the project must be installed with same build. please see attached.
Thank you. issue is solved
