dynamo script help - coordinates
CLMSJ
Message 1 of 26
CLMSJ
Hi, could anyone pls help me with updating my coordinate script? its supposed to take coordinates from the survey point but it doesnt seem to be anymore. I think its taking coords from the origin? any help would be much appreciated. Many thanks in advance
Replies (25)
Message 2 of 26
Tom_Kunsman
You might find more help in the Dynamo forums than here. Might also consider asking Claude or some other AI agent, as those might be able to help, or even provide a python script.
Message 3 of 26
CLMSJ
Hi, i cant find the dynamo forum, do u have a link?
Message 4 of 26
AEC_Revit_Lab
Your graph builds a translation from the Survey Point XYZ, so it misses the active shared-site rotation. Replace that transform chain with a Python node using `doc.ActiveProjectLocation.GetProjectPosition(point.ToXyz())`, then read EastWest, NorthSouth, and Elevation. That matches Revit’s Report Shared Coordinates. Hope this helps. If it solves the issue, you’re welcome to mark it as a solution so others can find it more easily.
Message 5 of 26
CLMSJ
Hi, many thanks for the reply much appreciated. However im totally new to dynamo and no idea how to do what you are describing. I got this script online which worked in last years version. Is it possible you could update it for me and send it back over so i can check it works? be much appreciated.
Message 6 of 26
pkomatlapalli
Hi @AEC_Revit_Lab ,
Could you please assist CLMSJ  if additional help can be provided.
Thank you for your time and assistance!
Let us know how we did on Trustpilot.
Pavan Kumar
Message 7 of 26
CLMSJ
is there any help out there for this please? much appreciation in advance
Message 8 of 26
will_young
Hi mate, I might have a solution for you, can you post a Revit model that just contains 2 piles for me to test?
Message 9 of 26
lauri_barnhart
Hello, @CLMSJ.
Just checking in to see if you saw the outstanding request by will_young. If you can provide the Revit model here that would be greatly appreciated so we can continue to support you.
Lauri | Community Manager
Message 10 of 26
CLMSJ
hi many thanks for this. revit file and pile coord script attached. i did notice that when u run the script for the first time it works. but when you then move the survey marker and run the script again, it then doesnt work
Message 11 of 26
will_young
Hi mate, I had a bit of time to rebuild the script and make it hopefully work for all situations.
Would be great if you can try the below and let me know if it works.
I made it so that it replicates the options you get for the Spot coordinate tool.
If you run in the player it gives the below inputs.
You just need to set up 3 parameters for eastings, northings & elevation.
Message 12 of 26
will_young
I just tested my end and it works fine on your Revit model with the below settings:
Message 13 of 26
CLMSJ
brillian will, thank you much appreciated. i will test it soon and let you know, im just working on an urgent project at the moment but will test it right after. 🙂
Message 14 of 26
lauri_barnhart
Hello, @CLMSJ.
Sounds like your question has been resolved. If it has, would you be willing to clicking 'Accept Solution' on the post that helped resolve your question?
Message 15 of 26
CLMSJ
Hi will, i have just tried to test it but it wont let me select more than one pile at a time when you click the "select" in the script? it used to let me
Message 16 of 26
CLMSJ
Hi not resolved yet, looks like a minor issue to sort still
Message 17 of 26
will_young
Hi mate, I changed the script so that rather than having to select each pile, you can just select one pile and it will apply coordinates to all piles of the same family.
Message 18 of 26
CLMSJ
When i do it, it doesnt seem to match? am i doing something wrong?
Message 19 of 26
will_young
Are the spot coordinates using survey point or project base point?
Message 20 of 26
CLMSJ
survey i think
