Editing Bolt Pattern Sketch
r_d_clarke
Message 1 of 8
r_d_clarke
I'm using Revit 2019 and am working with Bolts, Anchors, Holes from the "Steel" tab.  After creating a pattern of bolts, I can't seem to then edit the sketch to change my bolt layout.  The "Edit Sketch" button is greyed out when the bolts are selected.  Seems that the only way to change the layout is to delete the old set of bolts and create a new one.  Is there something I'm missing?
Replies (7)
Message 2 of 8
A_MAQ
Actually, you can not edit that.
The only way to change your sketch is modifying the parameters in properties palette. or delete your sketch and remodel it again.
Autodesk Expert Elite
Message 3 of 8
ennujozlagam
hello, is there anyway you can post your family so we can check? thanks
Message 4 of 8
YarUnderoaker
The bolts from steel tab is builtin family, it can not be checked!
Message 5 of 8
catalin_lang
The bolts/anchor/holes/shear studs (Steel tab> Fabrication Elements panel> Bolts drop-down) sketch cannot be copy.
Also the Contour cut(Steel tab> Modifiers panel > Contour cut).
These are known limitations in 2019 release.
catalin.lang
Message 6 of 8
catalin_lang
You can edit the sketch by changing the Length on Side 1/2 parameters, but this is not a "real" edit... the existing sketch is extended to meet the new length, but the center of the sketch and the orientation cannot be changed.
Also can modify the position/number of the bolts/anchors/holes/studs inside the sketch.
catalin.lang
Message 7 of 8
r_d_clarke
Yeah, I was afraid of that.  These steel tools are a great addition to Revit, but there's still room for improvement.
Message 8 of 8
Tina_six1WQZ3
Community Visitor
Community Visitor
In Revit 2025 i cant also edit Bolds...  And its not possibel to select and delete Bolds in a Plate (Steel)   Unbelivable...   There is no excuse for that.    Thousands of ours fighting people with Revit  Problems like this....
