DWG export issue
DWG export issue
Message 1 of 22
DWG export issue
Working on same project. On one computer everything is ok, on another is problem.
Exporting to dwg, open dwg file on layout tab missing title block. In rvt export settings everyting is set to plotable. Can't understand where is problem. The only difference is that one workstation has autocad other atocad LT, but when opening expported dwg files on both workstation, there are no title block. Both workstaions has latest revit updates.
Gatis
Replies (21)
Message 21 of 22
janis.prodnieks
Looks like the issue is with too long folder structure. The export happened just fine if the destination folder is on local computer or even 1 folder up the tree on our server.
However, an attempt to repeat the bad export to same folder deep down in our foolder structure from other computer wasn't successful and exported DWG was just fine. So why is the same location too deep for one computer and is OK for other computer?
Message 22 of 22
Perfect, i change export to desktop then it iiss ok.
Thank you
