DWG export issue
DWG export issue
Message 1 of 22
DWG export issue
Working on same project. On one computer everything is ok, on another is problem.
Exporting to dwg, open dwg file on layout tab missing title block. In rvt export settings everyting is set to plotable. Can't understand where is problem. The only difference is that one workstation has autocad other atocad LT, but when opening expported dwg files on both workstation, there are no title block. Both workstaions has latest revit updates.
Gatis
Replies (21)
Message 2 of 22
aleksei.tkachenko
Hello
Try to check if the settings for dwg export are the same.
Message 3 of 22
GatisM
yes, they are same. I also reinstall revit, autocad to get absolutely default settings, but no reason.
Message 4 of 22
aleksei.tkachenko
Could It be that you export views on sheets as external references?
Message 5 of 22
GatisM
when trying to export sheets as external references, in dwg where must be title block - they are missing.
Message 6 of 22
aleksei.tkachenko
My bad, wrong guess. If the settings for title blocks export are OK, then I don't really know how to help you. Seems like an issue for Customer Support to look at.
Message 7 of 22
ennujozlagam
@Anonymous hello, worse scenario try to unistall and reinstall your revit program it could be some files are corrupted. just a suggestion. thanks
Message 8 of 22
GatisM
already done, no changes.
Gatis
Message 9 of 22
ennujozlagam
@GatisM hello, is there anyway you can post some part of it titleblock? etc.. so we can check or pm me and send to my email add. thanks
Message 10 of 22
GatisM
seems it is something about image exporting issue. But coludn't understand it is revit or autocad LT issue.
- On machine with autocad everything works fine.
- On machine with autocad LT has two options. First option - exporting title block with images (logotypes), title block isn't exporting. Second option - delete all images (logotypes) from title block family and title block could be exported.
I will send you email with files.
1. rvt
2. dwg - exported from machine with full autocad
3. dwg - exported from machine with acad LT title block has images (in rvt family)
4. dwg - exported from machine with acad LT title block has deleted images (in rvt family)
Thanks, Gatis
Message 11 of 22
ennujozlagam
@GatisM Hello, thank you for sending the file, I tried to export into AutoCAD and there is no issue. Sorry I don't have Acad LT. My suggestion is to export as DXF file from Revit and dxfin in Acad LT, but not sure if this will work. Thanks
Message 12 of 22
I am having the same issue, the title block is not showing up in the export from Revit to Autocad. Did you find a solution to this problem?
Julia
Message 13 of 22
GatisM
read message Nr.10.
I think its Autocad LT and Revit export bug, issue somwhere, because, same problem was in other office.
Maybe try to delete some logotypes before exporting as I wrote in mesage Nr.10.
Message 14 of 22
Thanks, but those do not fix the problem. We do not have Autocad LT and I created a title block with just the outside frame and it still does not show.
Message 15 of 22
ovidiu_paunescu
Hello @Anonymous
Could you share a sample file (can be simplified) that doesn't export correctly?
Do you see this issue in different projects?
Do you see different behaviors in the same project on different machines?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 16 of 22
ovidiu_paunescu
Hello @GatisM
Same questions:
Message 17 of 22
This problem only happens for a specific project. I have checked it on 4 computers, and on 2 of them I have this issue. Is there a way I can send you the Revit file?
Message 18 of 22
April-2019 and still no solution... So sad
Message 19 of 22
MYS-JonathanT
I have a similar issue -
Revit 2019.2 / Autocad 2018
When exporting dwg or dxf the titleblock is not there, when exporting dwf/x the titleblock is there.
Does not have this issue on all machines , some it works fine. I have transferred the DWG import/export from the office template just to be sure . This happens when exporting one sheet or a set of sheets.
Out office standard is to issue each sheet as one DWG , not export as xref.
anyone with ideas ?
Jonathan
Message 20 of 22
janis.prodnieks
Same issue here on Revit 2020.2. Before 3 weeks sheets to DWG got exported correctly, now it suddenly doesn't work. Views are there but titleblock frame and text is missing. The layout of views is different than on the sheet. Viewport titles are missing.
From 1 computer all projects get exported wrong, form other computers same sheets get exported OK. If images are removed from the title block the export is OK. Except that image in a family nested into titleblock didn't export but all other geometry was there in correct layout.
Another hint - during the export process image files appear for a short moment and then disappear in the folder where exported DWG is to be saved.
