Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
DRAWING BEAM FROM POFILE BUT THE LENGTH PUT OVERSIZE WHICH I DIDN'T
3 REPLIES 3
jyh92213
161 Views, 3 Replies
Dear Masters,
I made revit pofile with 52.250m beam.
When I create in the template, it draw over 70m automatically.
Do you have any tips in this situation???????
3 REPLIES 3
msgambelluri
in reply to: jyh92213
A structural framing family will stretch to the length of where it is placed in the project (first click and second click)
It looks like your framing family is built so that it will stay at 52250 in length. The family reference planes are not logically placed since the right side of the member is placed next to the left side etc and that is why the family is behaving unpredictably when placed in the project environment. I recommend that you get familiar with creating structural framing families within the structural framing family template. You could use the OOTB revit framing Wx steel framing family as a guide on how structural framing should behave. Then you could attempt to create your family again. Thank you.
Marcello Sgambelluri
jyh92213
in reply to: msgambelluri
Thank you so much, Could I ask one more question?
i made void to cut for the anchorage, but when it import to the template it did not appear...
 could you let me know why ?
Sincerely,
Jeong
jyh92213
Could you ask one more question?
I edit the original profile to fit the centerline.
And then, I import to the templete using that profile, but the section for the anchorage which made with void is not appear.
Do you know why?
Forma Design Contest
Technology Administrators
