Draw leader/arrow lines with out text attached??
Is it possible to draw a leader/arrow head line to point to and object with text associated?
Lee.
Please illustrate your question. Your subject and question does not match.
Ok well in autocad you can draw an arrow/leader with out text attached.  Now in RST we find only way to do this is to use a full stop in text box then draw arrow/leader.
So we simply want to be able to drawn an arrow/leader on its own with no text.
Lee.
create a text style, make text size 0.1, choose arrow style desired and put a full stop for the text. At 0.1 height it is all but invisible.
Hi there:
Attached please find the Revit 2016 file with a <Leader only element> you may use.
Nothing more than an empty Generic Annotation Family, the key for this is to create an instance and make sure that the Number of Leaders is at least "1". Modify its properties to select the desired arrow head.
Hope this resolves your question.
Apparently, quietly and without fanfare, Autodesk has finally given us the ability to draw a leader with arrowhead attached to a truly blank piece of text.  I don't see any record of it prior to Revit 2019, but the help now says:
"Leaders can be placed without text in order to create an arrow. . Either place a leader and do not add text, or add a leader to existing text and remove the text note."
We can now celebrate in the streets over this long overdue feature, but the factory was very secretive about having slipped it in when we weren't looking, and made no mention of it in the "What's New" documentation.
adelarueter
came upon your comment. any idea how to implement this? the only way I know how to make a leader is with text, aside from the blank generic annotation trick. when I try to make a leader without text, I don't see any option to not have text. thanks!
