Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Doule Pitched Joist
6 REPLIES 6
1971 Views, 6 Replies
Doule Pitched Joist
I need to add a double pitched 10K1 joist in Revit 2009. Is there a way of doing this? Help would be much appreciated, Thanks.
Doule Pitched Joist
6 REPLIES 6
"Attach to roof" doesn't work?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
I
When I select the 10K1 joist (see image) I do not get the option of attaching to the roof. Am I missing something here?
Can you get a double pitched K joist?
You might have to use a generic steel truss.
When
When
Joe.Charpentier
Joe.Charpentier
"Attach to roof" is only available for truss objects.
The joist families provided with Revit are "Structural Framing" objects.
You will have to edit the family to make it double pitched. The truss families are very complex- If you have not worked with families before, doing this will be difficult.
There is an editing families tutorial, I believe- you 'll have to start with that.
Good luck,
Joe
Good luck,
Joe
Kathering
Kathering
Community Visitor
Community Visitor
Only truss can get the option of attaching to the roof.
The double pitched bar joist is structural framing, so there is no option for attaching.
You might need to adjust the pithced angle (a parameter that can be found in the element properties) to match to the roof slope.
Best, Edited by: Kathering on Jun 2, 2009 3:06 AM
Is this in revit 2010? I don't believe seeing it in revit 2009
