- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I have this Double Fields and Rebar Model doesn't match to Rebar Schedule
See attached Image for Reference
Hi All,
Hi @vgmontalban
You are probably using shapes defined using shared parameters that have different definitions, but same name.
This happens for example, for imperial and metric rebar shapes loaded into the same project.
For that shape that is not reporting the correct length, you should look at how the shape family is defined. Dimensions and assigned parameters.
@ovidiu_paunescu Sir is it Possible for me to delete the Rebar Shapes and how? I found out that I have two/duplicate rebar shapes? (see attached image file), in rebar shapes I have this 00 and M_00 Shapes and so on.
Yes, you can do that.
You can just delete them from the project browser.
You need to replace the shape for the bars that are currently using shapes that you want to delete.
To do that you can use a schedule to identify the bars, or delete shapes one at a time and see which elements depend on those. You will see an error message saying that some elements will be deleted.
Thank you sir @ovidiu_paunescu
