Hi, does anyone know a good way of using the same Structural Framing Member size for two different applications (one for a bearer and one for a joist for example) and having different Type Marks for each (B1 for bearer and J1 for joist for example). At the moment, I have to duplicate the Type and give it a slightly different name.
Solved by hmunsell. Go to Solution.
This is where i would use 'Mark' instead of Type Mark. That way you can use the same size Structural Framing member with a different identifying mark.
You can also use 'Comments' or another parameter that will help define what members you want to show on what sheets. For example, you could have a beam marked '01-B01' but have another beam marked the same, but apply a comment to each beam in different locations (I.E. Core Beam, or Cantilever Beam). Then when we make a Schedule, we can use the parameters to filter down what beams show.
I would just make a new Type....
When you place it you can specify the Structural Usage in the instance properties.
Howard Munsell
Another approach is adding Comments to the type mark label and enter an unique prefix in the Comments field such as J or B, so that you tag will read J_2x8 or B_2x8.
I have been doing something similar to your solution hmunsell and renaming the member each time it is used in a different situation. It would be great to be able to have a different Mark for the same member type without having to change its name. Perhaps using the Structural Usage field?
I tried this option, but it didn't work. If i change the one i duplicated (I.e B.1 to J.1) it changes all of the other B.1's to J.1. Not sure if I'm missing something. I don't want to have to use the Mark or adjust the name of the member. Any other options?
