Different lengths for a straight bar partition
ionut_sprincenatuVVRQX
Message 1 of 9
I have the following situation,
I copied a straight bar partition from one wall to another with the assigned constraints (the walls are the same, I chose copy and not propagate because I don't want to put the bending detail again, Revit 2024.1.1) and I have the following error:
 -the bars are 820cm long but the parameter read in the label and in the schedules is 825 and I don't understand why.
Replies (8)
Message 2 of 9
jay_colcombe
Rounding Tolerances
check your  reinforcement settings
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
You're right, I did add some rounding to the 50mm multiple but,
I need this when I have a length let say 343cm and I want it to be 345cm.
When I have a value that is already the 50mm multiplier, I don't want another rounding.
Message 4 of 9
jay_colcombe
It’s all personal preference.
You either draw it the exact length with the no rounding value
Or
You incorporate the Revit build-in Rounding and sketch it shorted to take into consideration the roundin.
Jay Colcombe
Message 5 of 9
ovidiu_paunescu
It may be that the bar is 820.00001 mm or something like that.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 6 of 9
I found out that the error starts with the 8th decimal place, and from here the program starts rounding.
I also found bars that are not rounded starting with 11 decimal places
Is there any setting in which the program calculates its rounding starting with my imput decimal place?
Message 7 of 9
jay_colcombe
From memory I am sure there is a specific Project setting for Rebar Length units and rounding preferences.
Manage Tab > Settings Panel > Project Units > Structural
Jay Colcombe
Message 8 of 9
ovidiu_paunescu
Hi @ionut_sprincenatuVVRQX
Rebar rounding is applied to the parameter values, not to the physical dimension of the rebar. If it was applied to the actual bar geometry, you can imagine that changing the rounding options in the project would cause all bars to regenerate and there would be a high likelihood for errors.
There isn't a setting that influences this. Revit uses a precision of 9 decimal places for geometry calculations.
I recommend you review how the concrete elements were modeled and also try to manually input a dimension for the rebar segment.
Message 9 of 9
The model was imported from Etabs and I think from here is coming all the problems. Tnx
