Different export of elements in one project
Hello!
When exporting to DWG, some elements, such as beams or columns, are exported as 3D solids, and some as blocks. What needs to be done so that all elements are unloaded in 3D solids?
I noticed that elements are unloaded in 3D bodies if combined with other elements. And if they are separate, then already in the block.
Fittings are also unloaded in blocks. What can be done to unload them in 3D bodies too?
mphungDCHNW
Before exporting go into "export setup" and change to "ACIS SOLIDS" in the "solids" tab
