differences between project parameter and shared parameter
A_MAQ
Advisor Advisor
A_MAQ
hello,
what is the differences between project parameter and shared parameter?
thanks
Autodesk Expert Elite
L.Maas
Project parameters can be created from shared parameters. But project parameters are only used in the project itself. A shared parameter can also be used in families and therefore in other projects.
HERE a blog post from Paul Aubin about the most common parameters
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
CAN WE USE PROJECT PARAMETER IN TAGING ?
AS WE KNOW WE CAN USE SHARED PARAMETER IN TAG
A_MAQ
Thank you for your reply i got what i want
