Detail lines get delete when remove dimesion constrain to it
knguyen12
knguyen12
Please help . . . I have problem with Revit 2016 detail lines get delete when I delete the dimension (which constraining to it)  only. Is there a setting I missed here?
this also happen when modifying a family, lines keep getting delete. so frustrating . . .
L.Maas
This should not happen. Detail Lines should not be deleted when dimensions are deleted. I also have never experienced this.
Can you show some screenshots or even better a screencast of what you are exaclty doing that makes this happening?
Louis
Please mention Revit version, especially when uploading Revit files.
knguyen12
Thank you for helping, this happening since I have Revit 2016, all other versions are fine.
Kathy Nguyen
Senior CAD Designer
MATRIX STRUCTURAL ENGINEERS
MBE | HUB | DBE | SBE
5177 Richmond Ave., Suite 670
Houston, Texas 77056
713.664.0130 (phone) Ext. 142
713.664.1370 (fax)
[email protected]
alan.quinn
I understand your detail lines are getting deleted. As EnlInt indicated this is not normal behavior. Can to make a screencast or post a small project that demonstrates this?
Thanks for posting.
knguyen12
Thank you so much for your help looking into these issues. I have attached the pdfs below.
Thanks, Kathy
