Detail Component is not loading in Revit 2018.2
Hi there
    I have a problem with loading one of detail components. It is not loading to my project. I have tried to load it by going to Annotate Tab and component. The component that I have had a problem with is "L-Angle-Bolted Connection 3-Elevation". Other items are loading fine. When I try to load this item, it keep showing the previous item that I use before. Is anyone has the same problem?
Thank you
Look for it in the family browser, details, and drag it onto your view.
Thank you so much! It is works!
