Cut a arrayed family instance with a ref.line or GM Void
- Mute
- Permalink
- Report
Hello fellow Revit-users,
I'm facing a problem which i can't find the solution to. So here I'm, hoping to get some answers.
I'm building a sloped quay wall, which is constructed with sheet piles.
Since the quay wall is sloped each sheetpile got a different top offset.
I tried modelling this by placing the highest sheetpile, array this sheetpile and then use the cut geometry to cut the sheetpile with a reference line. Doing this results in the following error.
I can cut the sheetpile with the reference line when in group editing mode.
But when I press finish the first sheetpile gets uncut...
I tried doing this by using a General Model Void which gives me the same results.
The reason I want to keep them grouped/arrayed is that there is a high change the constructor is chancing the type of sheetpile to a sheetpile with a different width.
Anyone can give me a tip for a way to do this easily?
Cheers,
David
