Elements disappear from plan view when moving Z level
nathanhayes98
nathanhayes98
I inserted a family into a Revit project and it was placed at level 0. I then moved it along the Z plane to just above 100m however in the plan I now can't see it when I could when it was at level 0m. The view range is set at unlimited for the plan view but it was still not visible.
Thanks in advance for any help.
Nathan
Luiscko
Ok there some information that you need to review  the first like you said is the view range, your cut plane has to be highest that your elevation that you can see it, if this does not working maybe you need to check the another that is related with your filter phasing, you can put none to see if you can look your element, if  you don´t see  with this two option go to properties and change your filter discipline to Coordination or Structural this is the most important elements that you can checkas.PNGass.PNGdffdf.png
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
