I am trying to create reinforcement in beam using python in revit. But it is giving me some error. i have tried everything but now i am clue less that what is causing the error. some help will be highly appreciated. Thanks in advance
# -*- coding: utf-8 -*-
import Autodesk
from Autodesk.Revit.DB import *
import clr
print("-------Generation of Beam Reinforcement-------")
doc = __revit__.ActiveUIDocument.Document
uidoc = __revit__.ActiveUIDocument
active_view = doc.ActiveView
def new_point(p_1, x, y, z, x_dir, y_dir):
new_point_1 = p_1 + x*x_dir
new_point_2 = new_point_1 + y*y_dir
return(XYZ(new_point_2.X, new_point_2.Y, new_point_2.Z + z))
elements = [doc.GetElement( elId ) for elId in uidoc.Selection.GetElementIds()]
all_rebar_types = FilteredElementCollector(doc) \
.OfCategory(BuiltInCategory.OST_Rebar).WhereElementIsElementType() \
.ToElements()
columns = []
beams = []
footings = []
rebar = []
for rebar_type in all_rebar_types:
rebar_name = rebar_type.get_Parameter(BuiltInParameter \
.SYMBOL_NAME_PARAM).AsString()
if rebar_name == ('#'+str(4)):
bar_type = rebar_type
break
for element in elements:
if element.Category.Name == 'Structural Columns':
columns.append(element)
elif element.Category.Name == 'Structural Framing':
beams.append(element)
elif element.Category.Name == 'Structural Foundations':
footings.append(element)
elif element.Category.Name == 'Structural Rebar':
rebar.append(element)
num_stirrups = 4 #Number of stirrups to add
stirrup_spacing = 1.0 #Spacing between stirrups in feet
stirrup_width = 0.5 #Width of the stirrup in feet
stirrup_height = 1.5 #Height of the stirrup in feet
for b in beams:
beam = b
beam_height = beam.get_BoundingBox(None).Max.Z - beam.get_BoundingBox(None).Min.Z
beam_width = beam.get_BoundingBox(None).Max.X - beam.get_BoundingBox(None).Min.X
beam_depth = beam.get_BoundingBox(None).Max.Y - beam.get_BoundingBox(None).Min.Y
print(beam.get_BoundingBox(None).Max)
print(beam.get_BoundingBox(None).Min)
p_1 = XYZ(beam.get_BoundingBox(None).Min.X, beam.get_BoundingBox(None).Min.Y, beam.get_BoundingBox(None).Min.X)
p_2 = XYZ(beam.get_BoundingBox(None).Max.X, beam.get_BoundingBox(None).Min.Y, beam.get_BoundingBox(None).Min.X)
lines = [[[Line.CreateBound(p_1, p_2)]]]
t = Transaction(doc, 'Reinforce')
t.Start()
rebar = Structure.Rebar.CreateFromCurves(doc, Structure.RebarStyle.Standard, bar_type, None, None, beam,
XYZ(0,1,0), lines, Structure.RebarHookOrientation.Right,
Structure.RebarHookOrientation.Left, True, True)
rebar.get_Parameter(BuiltInParameter.REBAR_ELEM_LAYOUT_RULE).Set(0)
#rebar.get_Parameter(BuiltInParameter.REBAR_ELEM_BAR_SPACING).Set(6)
# rebar.get_Parameter(BuiltInParameter.REBAR_ELEM_QUANTITY_OF_BARS).Set(lenght/8)
rebar.GetShapeDrivenAccessor().BarsOnNormalSide = True
t.Commit()
Solved by L.Maas. Go to Solution.
Better to post these questions in the Revit API forum.
Louis
Please mention Revit version, especially when uploading Revit files.
