connecting the analytical lines
Eng.LuayTareq
Eng.LuayTareq
Hi ,
I would like to get an easiest way to connect the analytical lines of the riser beams with the inclined (stringer ) beams , as shown below in the attached figures , hope to get the easiest solution .
With All My Respect and Thanks
A_MAQ
Hi @Eng.LuayTareq,
what I know about accelerating of adjusting analytical model is to check it manually , but you can use filters to help you in accelerating manual adjusting
Kindly find the attached file , it shows you how to use filters for that purposes .
Autodesk Expert Elite
