Column Filter Level
Hi guys, could anyone please clarify what is the exact meaning in column filters - Base or Top Level is below / above? I would assume that if I specify that smth is below level it would be anything below that level. It seems tho that it is only the next level below/above and does not apply to the level after (sub level).
For illustration I created a test file:
first image shows column correctly filtered be base level being at Level 1
second image shows filter based on Base level being at or above Level 1. For some reason it filters even columns with base level at foundation level.
third image shows filter based on Base level below Level 1. Only column with base at ground floor is filtered, not columns at foundation level.
Btw it is Revit 2016.
Basically I need to filter columns at certain levels to easily indicated full height columns, columns only up to certain level etc.
Thanks for any clarification on this.
