Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
colour filter not displayed correctly
3 REPLIES 3
Luis.vannieuwenhuyse
230 Views, 3 Replies
I would have liked to ask a question regarding 2 stuctural framing inside each other.
I have a steel beam that will sit in a concrete beam.
Now I have created a colour filter via my viewtemplate (background color) for the steel beams.
You can see in the attachment that one of the 2 steel beams is colouring.
The beams are the same length, and are cut in the same place.
What I also keep finding weird is that it keeps showing the hatch of the concrete beam.
Labels (4)
3 REPLIES 3
I am unsure from the description on how you have created this beam? Is it a Family or Group or Assembly or just drawn in the model?
In this model i simply just modelled them as single elements, I created a quick filter
Then when Viewing in a Section it works as intended
I would check what the Filter is referring and it relates to both I beam elements such as Type Name or materials etc.
As regards the concrete showing this will be the because the I beams are not cutting out the geometry of the concrete element but simple hosted within it.  You could create a masking region to remedy it?
Jay Colcombe
Autodesk Certified Instructor
Hi @Luis.vannieuwenhuyse
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
sorry for the late response
The family consists of 2 extrusions. The difference between medium and fine level was the answer.
Forma Design Contest
Technology Administrators
