Changinge Cell Height in Graphical Column Schedule
MatTheDrafter
MatTheDrafter
I'm a new user to Revit and still learning the program. I am wonder if there is a way to customize the column heights for graphical column schedules. As you can tell by the image I have uploaded that all my column locations cells are not large enough to hold all the locations provide. Thank you for any help you can provide.
twebb4CYQY
You can edit the Vertical heights of the cells Below the bottom level, via the Text appearance in the graphical column schedule properties.
Note it will change the cell height of the row above as well.
