Change the Section gap size
ArmanMargaryan
ArmanMargaryan
Is it possible to change the size of the Section gap by a precise number (see in the photo)? 
Thank you so much.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
In current version, I don't see there is any option to control the size/ length of the gap, only drag it manually. Maybe you post this topic in the Revit idea?
ArmanMargaryan
Thank you for your answer.
You can vote if you need this.
https://forums.autodesk.com/t5/revit-ideas/change-the-section-gap-size/idi-p/10454777
Arman Margaryan
Linkedin | Facebook
Voted! I don't need it too much but I every time I create a new section, I have to drag it manually which is relevant to the repetitive works.
ArmanMargaryan
Thank you very much
Arman Margaryan
Linkedin | Facebook
