Change the default settings for detail level of structural connections
joel.van.herwaarden
joel.van.herwaarden
Hi everyone,
This is probably not possible, but in Revit you only see your physical geometric representation of you structural connection when you set the detail level of a view to Fine. Is it possible to change this threshold to Medium?
I have views which are in medium detail level, but I want to see my connections. Otherwise I have to change multiple families to Fine...
Please let me know if there is a solution or a workaround.
RDAOU
@joel.van.herwaarden
In visibility graphics, you can set the detail level for Structural Connections category to show as Fine, if that doesn't work, you can still overlay 2 views (1 medium and 1 fine) on a sheet
joel.van.herwaarden
Awesome, this works perfect!
