Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Chamfered Precast walls change length when changed into a part in 2023
1 REPLY 1
darylkingsford
142 Views, 1 Reply
I am trying to produce precast shop drawings with chamfered vertical edges, I can place revels on the vertical corners of the wall and the original looks perfect,  but as soon as I assign it as a part the part becomes shorter then the original,  this  happens each time I use either the precast split tool or the make part tool, is there a reason for this???? How can I work around this issue? I can make multiple panels out of a wall by using the split part with profile and  gap, but this doesn't work for the ends of walls or walls that join at a corner, this is where I expect to use the vertical reveal,  but as mentioned when converting to a part the part is shorter in length. Any help would be  much appreciated
1 REPLY 1
Just in case anyone is having trouble understanding the problem, i have attached a picture
