Message 1 of 8
Cant cut any objects using void forms (Revit 2024)
- Mute
- Permalink
- Report
Im having trouble creating void forms to cut a slab in Revit 2024. As you can see above, I have created a void that goes through a slab/wall and get the same error every time, that there is "no solid geometry to cut". I originally wanted this to cut just the slab, which is sloped, as you can see by the solid mass on the right hand side, but since then I have been just trying to cut ANYTHING at all to see where im going wrong. I cant get anything to cut whatsoever. I have tried changing it to solid and then back to void, I have tried deleting the elements and creating new slabs.
Any help would be appreciated
