Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Cant add stiffeners
4 REPLIES 4
diego.veloso.98
316 Views, 4 Replies
Cant add stiffeners
Hello. I'm trying to add stiffeners to my beams but I'm having trouble in doing so. First, I receive the warning that the stiffeners are not visible in 3D view (first image), but that's not the case, since I checked the visibily of them . Second, I also receive the error that "the shape of the connected element is unknown" (second image). The beam family is one that I created using the default steel beam in revit, so I could have different widths for the top and bottom flanges.
4 REPLIES 4
Hi @diego.veloso.98
So if you are using Stiffeners from the Steel tab then you need to be in Level of detail fine to see them, course or medium wont show them.
The steel connections including stiffeners will only work when your familes have the correct shape defined as shown in this link - https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Rob Merriman, AEC Technical Lead, Graitec
Hey Rob, thanks for the help. Looks like I was missing a couple of steps, like the material and the shape, which I set as parallel I. But I'm still having trouble, but now with a new error, "StructuralSection parameters incomplete". What is those parameters that my family is supposed to have? Maybe something related to the name I gave my parameters? Thanks !
hI @diego.veloso.98
So in the following links it talks about the shape definistion, then the dimension and detailing dimension parameters. Your family must have these and they must be actactly as they are shown in the links
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-5C94C05B-3463-4492-B97D-BC9E622147B7
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-F987AEF5-8426-439C-BBB3-F2F53F0B956B
Thanks! But what if I want to have a beam that has different top and bottom flanges widths ?
